2013 Taurus Limited Hesitation/studder
Old Oct 31, 2019 | 11:36 PM
Mr_X's Avatar
Red face 2013 Taurus Limited Hesitation/studder
There is a slight hesitation/shudder while accelerating from 2500-4500 and is only getting more and more noticeable. No check engine light what so ever. No codes stored in the memory.
System was relearned from fresh. Spark plugs and oil change was completed (after hesitation started)
Switched a step up higher with gas. cant figure out what is causing this, Has anyone experienced this before? And if you have, what was the remedy? this is driving me absolutely insane..
Old Nov 1, 2019 | 12:22 PM
You might check the throttle body for deposits. If it needs to be cleaned, use only throttle body cleaner. Any other strong solvent could remove the anti-stick coating.
You might want to have someone hold the throttle pedal to the floor with the key on to do this. Whatever you do , don't attempt to move the throttle blade manually, that can damage the internals of the throttle control motor.
Old Nov 3, 2019 | 02:07 AM
Mr_X's Avatar
I will def try that out.
As temps start to drop here in Minneapolis, (30 deg) i went out to the car and used the remote start except it didn't start.
got in the car and tried to start at least two more times before it finally started. Sounds like a fuel pump to me, what do you think?
Old Nov 3, 2019 | 11:28 AM
I wish I had a good working chrystal ball to answer your question, but since it's covered with fog , lol , not good to speculate without confirming your suspicions.
When you say it wouldn't start, does that mean it wouldn't crank over or does crank over , but will not fire up and start running ?
Usually, but mot always, if a fuel pump is planning on going south, you might notice some higher speed sluggish problems.
Not knowing when you purchased the vehicle, as cold weather approaches , batteries that are borderline just don't supply enough power to get everything on line.and among the everthings, can be starting problems. Does your scan tool provide fuel trim info, if so can you post some of that info? Thanks.
Old Nov 6, 2019 | 12:41 AM
Mr_X's Avatar
The vehicle was cranking every time i tried, definitely not a battery issue. I will be hooking up the Autel to access the fuel trim and post results.
Usually the hesitation will start at about 10 mph and will continue at about 50 mph and will continue the more you accel, you will see and feel the engine drop in rpm slightly and jump back up quickly even though your foot is steady. you can also feel it more when your going uphill.
I was told by a fellow friend that the connectors on the fuel pump have a known issue and said that they sometimes build up corrosion on the connectors so ill be checking that. also i forgot to mention with my research that i have been doing i found that the Fuel Pump Control Module tends to go bad, so i replaced it from Ford (before the not starting issue i had) just to eliminate it all together.
What other known issues have you ran into with this car?
Have you heard of the issues i posted above?
Pretty much just trying to pick some brains and see what other people have ran into in the past.
Old May 31, 2024 | 08:08 PM
geoffgale0602's Avatar
Default Crankshaft sensor
Don't know if you ever figured it out but I went through literally everything you could think of and every experienced mechanic told me fuel pump fuel pump relay starter spark plugs I mean everything and it turned out to be a 20 dollar part called the crankshaft sensor but only thing is that you can't reach it unless you take the motor apart from the transmission but after I did it it'll start up every time and runs good
aldark
Oct 19, 2019 04:10 PM
MarkMandy
Mar 17, 2017 05:37 PM
gonzo51162@gmail.com
Feb 8, 2016 10:57 AM
detguy
Apr 1, 2014 10:16 PM
drewbaran
Nov 28, 2010 06:41 AM
