2013 Taurus Question
Old Mar 28, 2017 | 02:54 PM
Haw1936's Avatar
Default 2013 Taurus Question
I have a 2013 Taurus Limited. Great car! Enjoy the backup feature. Great gas mileage. Super pickup. Beautiful looking car and get compliments on it. Here comes the dropping boot! I have turned the lighting up as high as it will go for the dash, but the speedometer, 85% of the time, is invisible. I can't make out the speed. I am wondering if a light has burned out, if such exists?? If it does exist, where is its location and how difficult is it to replace?
Old Dec 20, 2018 | 01:54 PM
pfmerlino's Avatar
I just posted a similar problem with my Taurus. The speedometer dims at night or in an indoor garage when it should be the brightest. I cant get an answer for this issue.
Old Dec 29, 2018 | 12:21 PM
The panel dimming is a normal feature for over brite/ glare in low light conditions.
Old Dec 31, 2018 | 08:05 AM
pfmerlino's Avatar
I just cant understand that a dimming feature is normal under low light conditions. To me it should be the opposite.
Old Dec 31, 2018 | 09:32 AM
Some/later MY’s your able to cancel auto panel dimming through the Message Center.
When dimmed, can you manually overide the dimming feature with the panel dimmer control?
Old Dec 31, 2018 | 10:12 AM
pfmerlino's Avatar
I have turned off the auto dimming option to no avail.
Old Dec 31, 2018 | 10:23 AM
If in dimmed mode, can you manually raise lamp output over the programmed level using the dimmer buttons?
Old Dec 31, 2018 | 10:29 AM
pfmerlino's Avatar
The dimmer button is at it's highest level at all times. Any higher and the dome lights activate.
Old Dec 31, 2018 | 01:04 PM
PM sent
Old Dec 31, 2018 | 02:22 PM
With the lamps in manual mode, the auto backlight dimming HL ops should be canceled
ford2003
Jun 4, 2015 07:34 AM
wrocky
Sep 21, 2012 10:45 AM
wrocky
Sep 21, 2012 08:17 AM
hallie82
May 20, 2009 05:08 AM
llogan_jones
Jan 4, 2005 09:31 AM
