96 wagon will start but not run
Old Oct 23, 2006 | 04:43 PM
dallas's Avatar
Default 96 wagon will start but not run
It's actually a '96 Sable. Maybe someone here can help. This link will explain everything I've done so far: http://www.automotiveforums.com/vbul...d.php?t=633593
I know someone else must have encountered this problem.
Thanks.
Old Oct 23, 2006 | 07:56 PM
giantfan1226's Avatar
Default RE: 96 wagon will start but not run
if you give it gas when it starts will it stay running?
if so, i would just replace the idle speed motor(iac)
sometimes cleaning it wont do anything
hope this helps
Old Oct 23, 2006 | 08:30 PM
dallas's Avatar
Giving it gas doesn't help. It will run if I spray carb cleaner into the TB. I'll check the IAC, though. My son said it looked worn but that once the throttle is opened the IAC should affect the engine's running.
Old Oct 24, 2006 | 01:31 AM
94 4x4 ranger's Avatar
Try the fuel pump relay it is under the hood in a black box called the power distrubtion box swap the fuel relay with the A/C relay.
Old Oct 24, 2006 | 06:07 AM
dallas's Avatar
I'll check the relay, but unless it is intermittant it wouldn't seem to be the problem. The FP always works at initalization (key "on"). The system is filled with gas at 40psi, but quits when the engine starts up.
It failed all day long Monday, then fired up and ran fine Monday night as we were checking before locking it up for the night.
Go figure!
Old Oct 24, 2006 | 10:51 AM
The relay can cause this.[hr]They do work half *** when going bad
Old Oct 24, 2006 | 05:05 PM
dallas's Avatar
Started up again this morning.
On the pump relay: if the relay is intermittant, why would it ALWAYS work when the system is initialized (key turned to "on")? Is there a current load difference when the car tries to run that would cause the relay to malfunction sometimes?
Old Oct 24, 2006 | 11:38 PM
The contacts go bad.
Old Oct 27, 2006 | 10:53 AM
dallas's Avatar
After trying everything except changing the fuel pump we accidentally discovered that one of the sets of keys wasn't deactivating the security system. It would allow the doors to be opened and the ignition to be "excited"....but not allow the engine to run.
So far, everything is normal when using the other set of keys.
Go figure!
Laura W
Sep 21, 2010 08:33 PM
streetglide007
Apr 11, 2010 12:23 PM
99Escort20
Jun 10, 2008 09:35 PM
Lennygrt
Apr 30, 2006 08:55 PM
