'97 GL wagon 3.0L: Replaced CMP Synchro OK, But it's slightly misaligned. Now what?
Old Feb 23, 2012 | 12:06 PM
Colt Hero's Avatar
Default '97 GL wagon 3.0L: Replaced CMP Synchro OK, But it's slightly misaligned. Now what?
200k miles. I marked the position of the synchro body OK, but since the "vane" was so mangled by the old magnet destoying it, I couldn't be absolutely sure the "vane" on the new synchro ended up in the exact same position.
Obviously it's NOT in the same position because, although the car starts and idles well enough, it lacks power and the Check Engine Light comes on throwing spark plug codes (which seem to change randomly from start-up to start-up).
I COULD just yank it out and turn the gear a tooth one way or the other, but is there a more precise way to do it? If I go to TDC, that's STILL not going to tell me exactly where the "vane" needs to be (unless there's a mark on the synchro body for TDC, which I doubt).
Old Mar 11, 2012 | 11:40 PM
Colt Hero's Avatar
Looks like I finally got it right earlier today. Turned out the TDC mark on the damper was 90-100 degrees off (@ 3 o'clock) ... for whatever reason (bad harmonic balancer???). Last weekend, believing I had simply over-turned the crank, I was rolling it back 90 degrees to line up the damper groove with the cast iron TDC pointer on the block. This was proper procedure, but apparently wrong for this car. Today, after seeing the same thing again, I decided to just leave the crank TDC mark where it was (@ about 3 o'clock) and set the synchro to that. Took me 3 or 4 tries and I had the vane in the correct position! I could tell as soon as I started the engine that it was much better this time (quieter). Took it out for a 15 miles drive and no Check Engine light. I also installed all new (properly gapped) plugs and wires, although I have to say that I really couldn't feel any difference in pep, pickup, or power from the 200,000+ mile plugs and wires that were in there since the car was built in '97!
So two things learned here:
1.) You can't always go by the TDC pointer on the block. This car has over 200,000 miles on it and apparently TDC has shifted by 90 degrees (is this a bad harmonic balancer?)
2.) You can mis-install the CMP Synchro, have the car run rough, and still NOT get a Check Engine light!
Next order of business with this car is a metallic screeching at the serpentine belt area. I sprayed water on the belt itself (the vertical stretch that runs parallel to the firewall) and the noise quieted. But I also sprayed water on the alternator pulley with the same result! In fact, I could spray water on ANY pulley and quiet the noise. It's the original alternator and power steering pump, so either of those pulleys could be causing the noise. Serp belt, water pump and idler pulley bearing are about 4 years old. Guess I need to remove the belt first and start spinning the pulleys (listening/feeling for problems)? When I was turning the engine by hand there was a pinching rubber sound from the serp belt as it rotated. Is this a clue, or is this normal?
Might also have a head gasket leak. Need to perfom some kind of pressure test to see if I can get air or liquid to come out the side of the block.
ryche
Feb 27, 2015 01:35 AM
Deathstar98
Jan 27, 2011 10:26 AM
93f250xlt4x4
Jul 3, 2008 10:02 AM
93f250xlt4x4
Aug 29, 2006 04:02 PM
bbb
Dec 13, 2005 11:31 PM
