cooling tube
Old Nov 7, 2007 | 02:13 AM
rlevy64614's Avatar
Default cooling tube
my mechanic says me 1998 ford taurus se needs a cooling tube. what is this item he says its r usted and needs to be changed for big buks whats going on help help ehhhhh......
Old Nov 7, 2007 | 06:42 AM
way2old's Avatar
Default RE: cooling tube
Look behind the engine and you will see some metal pipes connected to the hoses. I think this is what he is talking about. They actually are the heater hose assembly.
Old Nov 7, 2007 | 08:27 PM
rlevy64614's Avatar
what do you think it will cost to replace......
Old Nov 8, 2007 | 07:02 AM
way2old's Avatar
If you can isolate where it is leaking from, you can purchase the part yourself and replace it. We have had some of the crimped portions of the hose leak and cut the crimp off and replace with silicone heater hose. Cost is minimal that way. Just takes a little time and effort on your part. Or call and ask how much it will cost to repair. Since your mechanic knows ahere it is leaking, how much does he want to repair?
Old Nov 8, 2007 | 01:20 PM
Larrywh's Avatar
Hi:
I just joined and saw this post and wanted to share what it cost me for the tube at the dealer with a dicount.
The tube is mounted to the fire wall on my 02 Taurus and was rusted too bad to do anything with so the cost was worth it to me. $58.00 was my cost plus $60.00 to install.
Larry
Doyle
Aug 18, 2006 11:53 PM
mitchelln
Aug 1, 2006 07:07 PM
racespeed200
Jan 17, 2006 02:06 AM
lucheech1
Dec 25, 2005 09:59 AM
elbert
Nov 19, 2005 01:33 AM
