im having to codes read on my taurus
Old Jan 18, 2007 | 06:14 PM
Taurus_SE_Sport_99's Avatar
Default im having to codes read on my taurus
hey, okay i went to autozone today b/c my service engine light was on and it read to codes!
code 1: p1744
code 2: p0401
does anyone knows what that means and does anyone know what would happen if i keep driving my car?
[IMG]local://upfiles/9148/3392F2FDDD5E4809A9CF2ED1DF33C4CE.jpg[/IMG]
[IMG]local://upfiles/9148/85DC6B90DF2B4810BE74248FEEBB65A1.jpg[/IMG]
Old Jan 18, 2007 | 10:14 PM
Default RE: im having to codes read on my taurus
DTC P0401 isEGR Insufficient flow Detected....
The EGR system is monitored during steady driving conditions while the EGR is commanded to On..Fails when the signal from the DPFEsensor indicates that EGR flow is less than the desired minimum
Possible causes....
Vacuum supply, EGR valve leaks vacuum/stuck closed, EGR flow path restriction, EGRVR circuit shorted to PWR, VREF open to DPFE sensor, DPFE sensor downstream hose off or plugged, EGRVR circuit open to PCM, VPWR open to EGRVR solenoid, DPFE sensor hoses both off or reversed, damaged/restricted EGR orifice tube, Damaged EGRVR solenoid ....
DPFE sensors commonly fail ....
DTC P1744 is TCC (torque converter clutch) excessive slip detected during full TCC engagement.
Old Jan 19, 2007 | 12:58 PM
for the DTC P1744 is TCC (torque converter clutch) excessive slip detected during full TCC engagement.
what would happen if i keep driving with this problem?
Old Jan 19, 2007 | 02:39 PM
Is this a high mileage unit?.. A 3.0 (2V) ?
Letting the TCC slip isn't a good idea if severe.. Especially if its an electrical component failure and a relatively easy fix.. The converter is a bit harder for a repair if its not the cause.. If equiped with a transmission control switch (TCS) cancel out the OD...
If its city driving without much OD application it would be less of a problem...
Old Jan 20, 2007 | 10:36 PM
it only has 106,000miles on it, so ur sayin i should stop driving in over drive? the dealer is supposly going to fix my car jan. 26th but we'll see
Old Jan 20, 2007 | 11:50 PM
What kind of driving are you doing? City or more highway use?
If your running at freeway speeds and you can easily detect a 'slip' then you might want to slow and cancel the OD on grades ect... If the reason for the stored DTC and the cause of theTCC slipping is due to a bad TCC solenoid or circuit, then you don't want to ruin the converter or trans.. If the torque converter clutch is going south, that letting it slip (if not severe) isn't a huge deal especially if a trans build or a reman will be the fix.. But anything slipping isn't a good idea.. Slipping generates heat 'quickly' and can cause other parts to fail...Did they give you a service advisory as to the repair?
Old Jan 20, 2007 | 11:56 PM
wheelsup68's Avatar
DPFE is probably the problem, and I agree with Hayapower, if you can avoid driving in OD till it is looked at professionally it may save you large repair.
Old Jan 21, 2007 | 04:43 PM
im doing both high way and city driving but mostly city. and only on the city drive is when it slips like when ur in first/second gear. but when im on the high way i dont notice a slip at all. the dealer is supposly goin to fix my car jan. 26th but i dont think they will. b/c they've been giving me problems lately
sllimbri
Feb 14, 2021 11:49 PM
Paul Polish
Apr 15, 2014 11:55 PM
twr7cx
Oct 22, 2011 03:13 AM
flavor4real
May 13, 2008 12:21 AM
flavor4real
Jun 27, 2005 08:20 PM
