No heat or a/c
Old Mar 10, 2007 | 11:57 AM
mddavis's Avatar
Default No heat or a/c
Awww man no heat or a/c in my taurus now. Rear window defrosts. interior winshield defrosts slowly. Dealer says it is a 100 just for diagnostic tests. No clue except i small pop was heard and a tuft of white smoke came from one of the vents above the radio. Please help
Old Mar 10, 2007 | 06:48 PM
goinstrong's Avatar
Default RE: No heat or a/c
Usually a fuse or breaker-fuse blows to keep anything from overloading and smoking. It sounds like you overloaded it - fuses usually don't smoke bad. Did you have the fan speed on high with the vents closed? (This would heat up the wiring). If you smelled plastic burning - you may want to get it fixed fast. Overloaded wires can burn off their plastic casing and catch on fire by throwing sparks to grounds. Keep the AC/heat off and fix it or you may want to start carrying a wrench (to undo the battery cables) and a fire extinguisher.
Old Mar 11, 2007 | 08:44 AM
mddavis's Avatar
Thanks. It wasn't a lot of smoke. Just a thin tuft of white smoke. I'll be taking it in!
ricknags
Apr 5, 2019 02:39 PM
Use Common Sense
Jun 25, 2016 01:30 PM
vivalasvegas777
Aug 29, 2012 11:07 AM
joshua.donelson
Sep 27, 2005 08:03 AM
wallygator
Sep 11, 2005 01:08 AM
