no start
Old Jul 25, 2008 | 12:21 AM
rlevy64614's Avatar
Default no start
for years ive had intermittant issues with the starting of my97 taurus. you turn the key and sometimes it just goes clik. after five or six turns it starts. my jiffy lube guy said the negative battery terminal was loose . could this have been my issue.
Old Jul 25, 2008 | 01:10 AM
Default RE: no start
Could be a connectivity issue,, starter relay, starter solenoid, or even the starter itself.. Also,, ignition switch power distribution out to the starter relay is through the trans range sensor.. Same sympton in neutral?
Old Jul 25, 2008 | 11:07 PM
rlevy64614's Avatar
its been doing this for 11 years.ive replaced the starter, battery cables, neutral switch, and then it turned out to be two shorted cells in the battery , i replaced the battery and it was fine for a year and then it came back. electric speicalist traced it to a loose wire under the dash and it was ok for a year. then it came back. advance auto took a free look at it and it a looose wire on the battery neutral terminal was found. after it was tightened it did it like crazy for the rest of the day and now the next day it seems fixed. its gone again. i love the car, it was a gift from my relative who died the next day so ive kept her. any thoughts. how much is the transmission range sensor
makuloco2000
Oct 22, 2013 09:46 PM
mayor
Nov 18, 2012 06:46 PM
NYCArmyWife
Nov 16, 2008 12:29 PM
iownslaves
Apr 1, 2008 06:03 PM
Ranger96
Jan 27, 2007 06:18 PM
