P0175 Bank 2
Old Aug 26, 2020 | 01:42 PM
Nvshell1's Avatar
Default P0175 Bank 2
Hello, I just changed the plugs on my 2005 Taurus SEL 3.0 24 valve DOHC. Took her for a drive and the engine light came on with code P0175, and on the dash the read out told me to check transmission. On the code reader below the P0175, it said, input turbine speed sensor A circuit malfunction. Can anybody help me out here and tell me what’s going on with the car. Thank you
Old Aug 26, 2020 | 07:37 PM
scott.butler4's Avatar
P0175 code is system to lean bank two.
Possible causes are -
Fuel pressure regulator vacuum hose or diagram leak.
Leaking fuel injectors.
Fuel return line restricted.
Fuel rail pressure sensor fault.
EVAP canister purge leak.
Personally I would go over the engine bay for vacuum lines disconnected/damaged while removing the intake manifold. Also check if your MAF is damaged/corroded.
Jerp
Aug 14, 2011 04:18 PM
forthvacav
Nov 24, 2009 02:35 PM
hermtm2
Feb 26, 2008 08:54 AM
rlevy64614
Oct 15, 2007 12:40 PM
rlevy64614
Aug 14, 2007 11:26 AM
