Problem w/bleeding rear brakes - '95
Old Dec 2, 2009 | 07:38 PM
Matty's Avatar
Default Problem w/bleeding rear brakes - '95
Hey all, hope you can help me out.
I just finished installing new (rear) calipers, pads, rotors on a 1995 Taurus. (the fronts were done a couple months ago). Mostly went smooth, but when it came to bleeding the brakes I have come to a perplexing problem - I can't seem to get them to bleed.
I have never run into this problem before, using the traditional two-person method. No fluid leaks noticed, and the level in the reservoir is not dropping when I try to bleed them. I pulled the rubber lines off at the calipers and some fluid does dribble out when I pump the brakes. I'm not sure if fluid should squirt out or if they are possibly clogged?
Any help or ideas would be greatly appreciated.
Old Dec 24, 2009 | 01:37 AM
stostefoone's Avatar
Default Problem w/bleeding rear brakes 95
Did you check the "Bronco Graveyard"? Have rear setups, although Im not sure a 8.8 is enough for 500 HP. May want to look into a 9" swap.
Old Dec 30, 2009 | 05:49 PM
glikark09's Avatar
The problem mysteriously went away a long time ago. I never did find anything wrong with the choke or vacuum leaks. Strange but true.
rod525
Nov 1, 2014 07:52 AM
DarylE
May 16, 2011 03:02 PM
mike93range
Jul 20, 2010 02:56 PM
91F150XL
Mar 21, 2009 06:15 PM
Coloradoskier
Jan 4, 2009 03:46 AM
