replacing side mirror cant figure out how to get inside door panel off
im replacing my driver side mirror on my 97 taurus and to do that i need to remove the speaker and to do that i need to take off the inside door panel which i cant figure out how to do. can anyone help me???
Hayapower--
I realize this is a bad way to start my first post............ but!
Many of us could learn from your experience regarding pulling a door panel. Unfortunately you did not post how to, appears you responded via email.
Everybody gains something from someone elses experience if he shares it with all.
Just my comments, no offense intended.
Foggy
Foggy
No offense taken, and there is certainly strenght in numbers and experience as I'm painfully aware, whitnessed too[sm=helpout.gif]andgrateful for....
The reason that I respond to some by email isn't to shroud info at the forum level on a help request.. The reason is, that depending on the job,if the technical info/illustrationsare lengthy it takes me extra time (some quite a bit if a large repair) to edit the written script and insert the images so that they make sensein a reply post as they don't transfer straight over,when clarity may be the key..Most timesit's a pictured/step process,and I may already have it data logged and it's just easier on me to email/send.. Sometimes membersposts without doing a forum search for a particular help topicthat may havebeen covered already, and searching forums can certainly be time consuming looking for specific needs.. An an email or repost from a previous thread is just not having to re-edit over and over..
Trim Panel, Door
[/align]Front
Removal
[ol][*]Remove cover behind inside door handle.[*]Remove plug button from bottom of pull cup.[*]Remove screw retaining front door trim panel.[*]Remove sail speaker grill, if equipped.[*]NOTE: Do not attempt to remove more than one pushpin at a time.
Using trim removal tool or equivalent, remove the door panel by pulling one pushpin at a time from the inner door skin.[*]Disconnect electrical connectors as necessary. [/ol]
[ol][/ol]
Installation
1. Follow removal procedure in reverse order.
2.Replace all removed pushpins with new pushpins.
Front Door Trim Panel
[IMG]local://upfiles/6756/A38E8C6391C04A65901B87EA3ABCE90B.gif[/IMG]
[/align]Front
Removal
[ol][/ol]
Installation
