Taurus girl... mechanic BF too busy
Old May 4, 2023 | 10:22 AM
2005Taurus's Avatar
Default Taurus girl... mechanic BF too busy
I've got a 05 Ford Taurus SE Flex and the thing cranks but it will not start. It was cranking and starting sometimes but now it just cranks. The battery is good, fuel pump is not kicking on but I'm not sure if there is a spark or not because I don't know how to check it. A guy loaned me code reader and it comes up five codes, two pending is what it says. P1235 , p0191 (fuel rail pressure sensor ckt range performance,) p0606 (PCM processor fault )0191.
Old Mar 23, 2024 | 10:33 AM
Difficultbill's Avatar
Default Fuel pressure
The fuel pressure is ran by vacuum. The vacuum hose is probably cracked. While you're checking it look at the other vacuum hoses. The engine heat will eventually make them fail. I use fuel line for PCV and brake booster. Also look at the plastic Ts Ls and straight couplers, they get brittle and crack. You can get them at the parts store
macarose
Apr 12, 2018 08:13 AM
steven10101989
Aug 17, 2017 08:03 PM
aircop2000
Oct 30, 2010 05:03 AM
ikala476
Aug 28, 2009 07:56 AM
dmoyer
Dec 14, 2008 09:51 PM
