00 taurus starting issues
Old Dec 14, 2008 | 09:51 PM
dmoyer's Avatar
Default 00 taurus starting issues
2000 Taurus 24 valve will occasionally not start. Engine will turn over but will not start. It seems to be when the car has sat a while (overnight) in garage. Will eventually start. Does not seem to matter if it is hot or cold outor what the fuel tank level is. Ford garage changed fuel pump relay. Same problem. It sounds as though the the fuel pump primes when you first turn on the ignition.Been an intermittant problem for about 3 months but seems to be gettingmore frequent.Any thoughtson this issue would be appreciated.Thank you.
dwarber
May 4, 2025 11:31 AM
amtran8454
Nov 11, 2012 06:15 PM
dmoyer
Dec 14, 2008 10:28 PM
Allnbrgdn
Oct 11, 2006 02:21 PM
Grabauaz
May 18, 2006 09:23 PM
