Will not start
Old Dec 19, 2007 | 09:23 PM
tractorcab's Avatar
Default Will not start
My son's 98 Taurs will not start. I have check the fuel pump and that is working. The gas line is not frozen as it has been in the garage for 3 days now.It would appear their is no spark going to the plug what should I check next? The car did sit outside for a couple of weeks as he can not drive due to sugery. He is getting close to being released what else can I check?
Old Dec 20, 2007 | 11:41 AM
BRETM's Avatar
Default RE: Will not start
Need to get a spark tester to see if you actually have no spark, also check fuel pressure even if the pump runs, it could still produce low pressure. Also check to see if the check engine lamp goes out while cranking. That will tell you if it see an RPM signal to the PCM.
bbeaufordf150
Feb 3, 2009 02:38 PM
NYCArmyWife
Nov 16, 2008 12:29 PM
hornet01
Mar 9, 2005 05:36 PM
Julian
Jan 24, 2005 09:38 PM
