Ford Tempo/Probe These small cars offered a sporty feel and affordable price.
1989 Probe won't stay running
Old Mar 4, 2012 | 03:09 PM
fiestyfeista's Avatar
Default 1989 Probe won't stay running
I have an 89 Probe that kept cutting out while driving. It finally stopped running all together. I have replaced the distributor cap, spark plugs, fuel filter and fuses. It will start but then won't stay running. Any suggestions what else to try. It is getting power from the starter and to the starter.
Old Mar 4, 2012 | 04:07 PM
We usually need three- four things for the engine to run.
1. Fuel
2. Spark
3. Air
4. The above 3 in the right place at the right time.
The easiest thing to check for is air, make sure the air filter is not plugged.
Then the next easiest is to check for spark.
Then you verify that you are getting enough fuel at the right pressure.
If you are getting the above three the last requires a compression test and most of the time one of the above three could be the problem.
Old Mar 6, 2012 | 05:00 PM
Thanks Hanky, I'll get all these checked out.
Old Mar 12, 2015 | 11:51 PM
beaglerock's Avatar
Sounds like the igniter to me as I had an 89 w / turbo and that puppy will will stop you in your tracks also check the fuel pump relay on the firewall
jkkay
Feb 24, 2021 03:39 PM
Jstew
Jul 5, 2011 02:28 PM
rmcard
Dec 17, 2006 06:30 PM
cruzandkathy
Jul 30, 2006 04:04 PM
chaumer
Feb 20, 2006 03:37 AM
