1994 Thunderbird Speedo not accurate and shifting to early
Old Feb 6, 2021 | 12:10 PM
Billys’33s's Avatar
Default 1994 Thunderbird Speedo not accurate and shifting to early
Hi guys
so I recently picked up a 94 Ford Thunderbird and I notice after a few days of driving it that the speedo is off by 5-10 mph, it’s not really a big deal to me except when I slow down to turn it stays in drive at 20 on the gauge and it Luggs in that gear
should I be concerned or is it ok for it to do that? And how would you go about calibrateting it?
Old Feb 6, 2021 | 01:11 PM
There could be more than one problem.
Check the speedo drive gear where the cable attaches to the trans.
If trans downshift linkage is not adjusted correctly it will not downshift like it is supposed to.
Old Feb 6, 2021 | 11:41 PM
raski's Avatar
Check the vehicle speed sensor.Not sure but if your Bird only has one,it will affect both the speedo and the way the transmission shifts.It is either mounted on the differential or on the transmission tailshaft(or both).You didn't mention what engine you had.
https://www.rockauto.com/en/catalog/...d+sensor,10634
Old Feb 13, 2021 | 08:41 AM
raski's Avatar
Looks like another first time post, run and hide.
Bibi 05
Mar 22, 2020 12:13 PM
frankyboy
Jul 25, 2016 05:08 PM
chavous1
Apr 20, 2016 11:00 AM
iowathunderbird
Aug 31, 2007 07:35 PM
RaleighRay
Dec 15, 2006 01:31 PM
