'64 T-Bird Trans & Radiator Issue
Old Aug 4, 2012 | 08:01 PM
  #11
johngg's Avatar
There will be a pan under the fly-wheel, Remove this pan and find the plug.
Have a LARGE pan ready, Some of these torqe converters can hold 8 quarts.
The C-6 tranny are 1 of them (I think...)
Old Aug 5, 2012 | 08:32 AM
  #12
qtband's Avatar
Anyone know the capacity when you do a torque fill?
Old Aug 5, 2012 | 08:57 AM
  #13
bandit1948's Avatar
if there is a drain plug on the torque converter then it will be on the bottom of the converter ! roll the torque converter around until the plug is on the bottom, take it out and drain the converter ! don,t forget to put the drain plug in and tighten it pretty tight !
Old Aug 5, 2012 | 03:52 PM
  #14
grindman's Avatar
the whole trans. is about 17qts and btw it's measured in pints so buy at least 17 qts of type F trans. fluid that should get it pretty close to being full as like I said before don't overfill it
VMChief
Feb 18, 2014 07:25 PM
conanalois
Aug 31, 2013 06:16 AM
surferbum
Oct 3, 2011 04:48 PM
Boeing777ex
Mar 31, 2009 02:04 PM
factory310
Apr 28, 2007 06:23 PM
