78 Tbird headlight problem
Old Mar 22, 2015 | 12:04 PM
Paul Clayton Thomas's Avatar
Default 78 Tbird headlight problem
Here it is, replaced switch because lights were cutting off after 10 minutes or so.
Now, they are still doing it. Help!!
Old Mar 22, 2015 | 01:57 PM
Hi Paul,
If everything is original,,,,,, and you replaced the headlight switch , and,,,, it is still opening the breaker in the switch, that is most likely caused by an excessive current draw in the headlight circuit.Might be a good idea to check the wiring from the switch out to the headlights, a wire may be pinched or possibly rubbing through to ground.
You might check the fuse that supplies the headlights for a corroded or poor connection.
canuck17
May 16, 2010 03:21 PM
El big joe
Apr 27, 2006 12:10 AM
Stanley Rockafeller
Nov 7, 2005 04:36 AM
ehkneebreeashun
Jan 12, 2005 03:22 PM
