94 bird 4.9 fouling #2 plug please help
Old Oct 1, 2007 | 04:25 PM
jonrock's Avatar
Default 94 bird 4.9 fouling #2 plug please help
I'm stumped. I have a problem with my #2 cylinder. It just fouls the plug.
Heres what I did.
Swapped coils.
swapped injectors with a different cyl.
Changed the plugs and wires
Did a compression check... all good.
looked at the cam and rockers ..seem fine.
Could I have a problem with the edis module or ecm. Being it fouls to the point that gas comes out the exhaust I don't drive it. No codes due to the battery being out. all the other cylinders are good. the wire is sparking well when i remove it from the plug while running.
I don't know where to go from here. any suggestions?
94 bird 4.9
Old Oct 6, 2007 | 05:05 PM
goinstrong's Avatar
Default RE: 94 bird 4.9 fouling #2 plug please help
4.9? You mean it has a 300 cubic inch truck engine? Or did Ford make a smaller block than 302 that year? Oh well at any rate the plug is fouling - with oil? or blowing off the metal tip completely? (detonation) Plus if the battery is out how do you start it?
Old Oct 6, 2007 | 06:07 PM
jonrock's Avatar
sorry its a 4.6. Fouls with gas, as if the plug was not firing, but it is.
subquanta
Mar 7, 2013 03:23 PM
beaners
Mar 23, 2010 06:45 AM
REORACING
Aug 17, 2009 05:55 AM
coater
Nov 25, 2005 05:01 AM
coater
Nov 21, 2005 02:26 AM
