electrical trouble
Old Apr 8, 2011 | 07:45 PM
docmatt's Avatar
Default electrical trouble
1996 thunderbird. turn signals don't work. hazard don't work. brake lights don't work. bulbs are good, fuses are good, flasher brand new. power getting to fuse. can't figure out problem. anybody have any ideas?
Old Apr 9, 2011 | 03:12 AM
Do you have the owner's manual? If so, check which fuses control those lights . There could be more than one . Also check for power after the fuse if you haven't done so.
You might try moving the harness going up to the signal light switch assy it could have a broken wire feeding the switch. Last but not least the signal light switch itself could be defective.
Old Apr 9, 2011 | 01:38 PM
docmatt's Avatar
Default Elect. checks
I tested every single fuse in the car and engine compartment. Elec is flowing through the fuse. The hazards and brake lights are not working, would the turn signal SWITCH (lever) have anything to do with that problem?
Old Apr 9, 2011 | 02:48 PM
Yes, the signal lights, stop lights and hazard flashers all go thru the signal lite switch assy.
Old Apr 17, 2011 | 09:38 PM
thund3rchick3n's Avatar
Ground.
willijimon
Oct 21, 2018 08:07 PM
Kaliforniakidd
May 4, 2011 02:30 PM
Bronco76Ranger00
Nov 8, 2009 08:24 PM
mrwhipper
Dec 23, 2005 06:10 PM
mrwhipper
Apr 18, 2004 09:33 AM
