motor swap
Old Mar 21, 2007 | 08:50 PM
rustbucket89's Avatar
Default motor swap
my sister recently totaled out her 98 windstar and has a 3.8L engine in it..i have a 93 thunderbird with the 3.8 that has way over 200k on it..i was wondering if the motor from the windstar would have the same bellhousing shape and motor mounts...also does anyone know what else i would have to do to make this motor work in my car?
Old Mar 22, 2007 | 01:21 AM
goinstrong's Avatar
Default RE: motor swap
The computer would work. But you would have to change the intake and exhaust manifolds to have the sensors and setup that work with your computer. The engine mounts are likely also different so you'd have to swap on yours (provided they bolt on the same to the block). The number of bolts and spacing from each other from theMAIN block to the trans. bellhousing (not starter or block plate bolts,etc.) will tell you if the fit is the same. Either that or find someone (perhaps at a local salvage yard) who has a Hollander interchange manual (expensive book to have) for those years.
Old Mar 22, 2007 | 01:46 AM
well i guess i'll just have to see when the motor is pulled out this weekend...fords are awesome after what happened to this van!! after being totaled itstill starts and runs like a champ!!
conanalois
Aug 31, 2013 06:16 AM
midnitev2
Mar 21, 2006 05:37 AM
Zeusfan
Dec 9, 2005 09:34 PM
Deviancekicksin
Jun 3, 2005 05:11 AM
bigbronc
Apr 10, 2005 10:34 PM
