02 e350 rear ac line not cold!
Old Jun 29, 2021 | 01:06 PM
Steadyclimber's Avatar
Default 02 e350 rear ac line not cold!
Hey
the front blows cold the rear blows regular air. I check the rear blower motor and door. It works fine. U watched it open and close when I switch from ac to heat. I noticed the rear lines never get cold. Is it clogged? What can I do?
thanks
Old Jun 29, 2021 | 07:16 PM
Doe the rear blow cold air at any time?
Old Jun 29, 2021 | 10:43 PM
No just the outside temp air. I checked the blend door an it works fine
Old Jun 30, 2021 | 12:13 PM
I needed to know if any refrigerant was getting to the rear evaporator, even for a short time.
Old Jun 30, 2021 | 12:39 PM
I don't think so. I have never worked on an AC system before. But the rear line never get cold. Clogged?
Old Jun 30, 2021 | 08:13 PM
There is a TXV, thermal expansion valve in the rear that is probably clogged or just not functioning.
Not being familiar with A.C work, I would suggest you have a shop equipped to do this work do the job. It can get a little involved and can leave you pulling out your hair.
If it was as simple as taking out one part and installing another , that is only part of the problem. Some special equip and it's use are required..
Old Jul 8, 2021 | 01:12 AM
Jc7zero's Avatar
Similar situation here. Front blows cold and rear blows cold and gradually turns to warm or hot.
jacked_72
Feb 3, 2020 10:44 AM
vanlife
Mar 8, 2019 12:58 AM
tarosean
Sep 14, 2014 11:34 PM
chp1959
Apr 21, 2009 12:22 PM
bell1234
Jul 1, 2005 08:19 AM
