02 windstar dlc
Old Jan 26, 2011 | 01:47 PM
bertiespeed's Avatar
Default 02 windstar dlc
Cig lighter and dlc both have no power is this common . #17 fuse in cabin is intact so im thinking a cut some where in wiring .. Have cel and get error on obd2 reader cause no power at DLC ..
Old Jan 26, 2011 | 06:33 PM
way2old's Avatar
Did you check fuse with a test light or a voltmeter? Or did you try a new fuse? I have seen fuses blow just below the top where the fuse reads good on both sides.
Old Jan 26, 2011 | 07:08 PM
I did try another fuse and nothing happend . Going to check if theres power at the fuse bank itself tommorow .
Old Jan 27, 2011 | 06:40 AM
Use Common Sense's Avatar
Just out of curiosity, did do you have the ignition switch on the "RUN" position? I believe there is only power to these in the "RUN" position.
Old Jan 27, 2011 | 03:47 PM
i know for the dlc needs to be in RUN position but think it is hot for the cig lighter
Im getting power at the fuse bank so there must be a splice somewhere after the fact .time to go fishing i guess !
Old Jan 27, 2011 | 05:57 PM
way2old's Avatar
Here is a picture that might help the fishing expedition. You may need to enlarge it.
Old Jan 28, 2011 | 05:30 AM
Thanks ! i havent been able to find a manual for the van yet either
Old Jan 28, 2011 | 03:25 PM
Found a coolent leak pooling on top the front valve cover area around the injectors looks like its comming from under the intake is this a common thing
bertiespeed
Jan 26, 2011 01:41 PM
ranshells
Jan 14, 2011 11:13 AM
doodah
Jul 24, 2009 05:23 AM
