03 f-150 frame cracking
Old Sep 5, 2006 | 05:45 AM
03bandit's Avatar
Default 03 f-150 frame cracking
I bought this truck 5 months ago and have had the same area welded twice now. Its cracking at the cross member welds on the frame rails. Whats causing it? It also has a 6"-5" lift and sits on 35" tires.
Old Sep 5, 2006 | 08:01 AM
94 4x4 ranger's Avatar
Default RE: 03 f-150 frame cracking
I had a 85 4x4 150 that did this but it was by the power steering box.I finally got it fixed righj by a good welder.It olny took about 10 times the last time the guy put plates in.
Old Sep 7, 2006 | 11:59 PM
Mulletman's Avatar
An expert weld should take care of the cracks. Especially since it is so new.
Old Sep 12, 2006 | 12:23 AM
sean08's Avatar
You coul drill a hole at the end of the crack to prevent further cracking, then grind the crack slightly into a V and preheat it to somewhere around 250 deg and weld it up. If you're not confident about doing this yourself better ask a reputable welder.
prestigeplumb.661
Feb 15, 2020 10:29 PM
karguy427
Nov 28, 2006 04:32 PM
my73ford
Mar 19, 2006 04:57 PM
hanswilhelm
Dec 29, 2005 05:04 PM
STEVE1103
May 17, 2005 09:55 AM
