05 freestar no start weak spark
Old Oct 14, 2011 | 06:59 PM
souphound's Avatar
Default 05 freestar no start weak spark
good fuel presure, weak yellow spark cranks but will not start
Old Oct 14, 2011 | 10:54 PM
cougar_fan's Avatar
Welcome to the forum! IMO, most likely: bad battery or poor battery connections. Possibly: bad ignition control module. A lot less likely: bad PCM, bad CPS (crankshaft position sensor) ... you need to be more specific about what you did or how this happened - for instance, did you do any repairs on, or additions to the car right before this started, or did you cross a water stream and soaked the engine, or did you keep it parked for the last six months and now it's not starting ... you got the idea.
Cheers,
cougar_fan
Old Oct 14, 2011 | 11:26 PM
Use Common Sense's Avatar
"Good fuel pressure"...What is the pressure reading?
"Weak yellow spark"...Could be a weak coil pack, excessive gap on the plugs, high resistance in the plug wires or a combination of all. A weak coil spark will not be able to cross the plug gap under compression. If too much gap, same thing. Also plug wire resistance increases with age causing weak spark. If not done, I would replace the plugs, wires and coil pack.
JCtrayer
Oct 28, 2011 05:32 PM
Rogerseric
Aug 12, 2011 12:34 PM
forzabianconeri
Feb 18, 2008 12:40 PM
austin
Sep 24, 2006 11:35 PM
jcwilliamsjr
Jan 18, 2006 06:55 PM
