'05 Montego AWD
Old Feb 29, 2016 | 06:34 PM
Montegoman's Avatar
Default '05 Montego AWD
Hello, about three years ago the AWD malfunction message and TC light came on. Code P1889. The Ford dealer went thru the ridiculous trouble shooting and parts replacement as per the TSB on this issue. Problem could not be resolved so the dealer said I could purchase a new rear end for $1800 or they would get a used one from a yard. I settled on the used one since it was only $250. After all was said and done, it still cost almost $1800 between all the labor and different parts. A year later, the message and light came back. I didn't have the money to fix it at the time and, quite frankly, didn't want to deal with another rear end going bad. My question is can the drive shaft to the rear differential just be removed and driven as a front wheel drive vehicle? I've already been doing it without issue, but now the inspection sticker is coming due and I don't believe it will pass with the TC light on and "AWD malfunction" in the message center. Please help. Thank you.
Old Mar 1, 2016 | 12:30 PM
greasemark's Avatar
These rear ends had a ton of problems with the pumps in them; you might check the net for a cheaper or DIY soloution to this.
I replaced a ton of these rear ends, and I agree, the TSB didn't ever work in the ones I saw.
Old Mar 1, 2016 | 01:08 PM
Montegoman's Avatar
Thank you grease mark, but I guess the question is can the rear drive shaft be removed and be legally driven this way or am I forced to somehow repair or even buy another rear end?
Old Mar 2, 2016 | 12:24 PM
Alanah_Rae's Avatar
I think you have to replace it !!
Old Mar 3, 2016 | 02:09 PM
greasemark's Avatar
yes, you can most definitely remove the rear driveshaft and drive it; thats how we used to diagnose them. It will just be a FWD car; and if it has damagaed bearings, they will still make noise. You'll have a flashing light or two, but other than that, it should be just fine.
I've driven these all over without drivesahfts, without any kind of driveability problem.
Old Mar 4, 2016 | 12:03 PM
Alanah_Rae's Avatar
agreed with you !!
Old Apr 2, 2021 | 05:02 PM
Justin Spears's Avatar
Default 05 Montego AWD malfunction, trac control, whining noise.
You seem to be explaining a problem I'm having. Any input on my 05 montego and the awd malfunction with trac control light. It also has a whining noise and seems to be in limp mode
.. Please give me your expert advice on what I can do.... Thanks in advance.
Timesnow
Feb 20, 2026 09:28 AM
Dustin Smith
Mar 10, 2020 08:38 AM
timmytaurus
Jul 18, 2015 06:51 AM
bpdx2003
Mar 11, 2014 12:41 PM
Ron22
Feb 17, 2013 12:39 AM
