1999 f-150 oil pan leak
Old Sep 1, 2007 | 04:52 PM
hwt03's Avatar
Default 1999 f-150 oil pan leak
I have a pin hole in the oil pan and need to replace it. My question is....can I swap out the oil pan without pulling the engine? Not sure if there is room to clear the suspention. May just jack up the engine alittle. Thats for the help
Old Sep 1, 2007 | 05:29 PM
david paul's Avatar
Default RE: 1999 f-150 oil pan leak
if its where u can get to it get a local welder to weld it or braze it one if not u will have to unbolt motor mounts and use a cherry picker{engine hoist} to raise engine enough for oil pan to clear suspension
Old Sep 1, 2007 | 08:29 PM
hwt03's Avatar
Thanks David Paul....what about some liquid steel, atleast temporarly? Just had the starter go last week and had to wiggle it out against the oil pan, never expected to cause a leak. Then there was a broken tie rod and front brakes, that Dodge Ram is looking better and better.
Old Sep 2, 2007 | 08:06 AM
david paul's Avatar
if u get it cleaned real good I've had good luck with jb weld its a two part epoxy that u cut off a piece the size u need and knead it till it changes color the apply it on hole and let it set up
jcasaccio
Oct 7, 2018 08:02 AM
tony tiger 54
Apr 30, 2011 02:53 PM
fordphanatic
May 25, 2010 09:25 PM
carlzt
Jan 11, 2009 02:07 AM
sjwoody
Jan 19, 2007 07:32 PM
