1999 f150 no brakes when engine running
Old Feb 22, 2014 | 10:41 AM
joekier's Avatar
Default 1999 f150 no brakes when engine running
I just replaced all parts on the front and rear brakes. Drums, shoes, cylinders and hardware. Rotors, calipers and shoes. The master cylinder never ran empty. I did the rear brakes on one weekend and had a soft pedal but it still worked. I did the front this week end and when I bleed the brakes I have a solid pedal until I start the engine - then I have no pedal. With the truck off the ground the brakes do stop the wheels but there is no pedal. I've bled the system at the master cylinder and brakes. When I remove the vacuum from the booster I have a solid pedal but when the vacuum is restored I loose the pedal. Any ideas as to what I might have missed.
orechia
Dec 30, 2010 06:04 PM
96F350Panel
Nov 27, 2007 02:59 PM
flatheadfooser
Aug 12, 2007 11:57 AM
rrmojica
Dec 17, 2005 02:24 AM
hightonedsob
Jun 12, 2005 09:29 AM
