2000 F250 7.3 Transmission leak only in reverse
I have a 2000 F250 7.3 4 WD crew cab. It is leaking transmission fluid pretty bad whenever we go into reverse. Doesnt matter if there is a load or not, or uphill, down hill or flat ground. What could be the reason? Thanks in Advance!
You will need to get up there with a flashlite and look at the back of the shift rail cover. The rails had a flat plug jammed in there for each of the 3 rails kinda like a freeze out plug but the size of a dime. It could be the plug came out, don't know without actually looking.
This applies only if you have a stick shift trans.
paddish
Jul 24, 2007 07:45 AM
