2003 Windstar
Old Oct 12, 2018 | 04:26 PM
daddyblaize's Avatar
Default 2003 Windstar
Who has replaced Timing cover gasket without removing engine?
Old Oct 14, 2018 | 11:38 AM
It’s doable.
Close quarters, the cover studs need to removed to be able to lift the cover clear..
Old Oct 15, 2018 | 01:34 PM
Default "It's doable...."
Hayapower thanks man I figured as much--I took one look and though the same. I've got a coolant contamination issue after having just installing this engine and I'm trying to rule out a bad engine. I'm going to make a plate out of some plate stock with a stencil of the water pump gasket a pressure valve will be installed and through it pressure applied to find the leak in the block.
daddyblaize
Feb 20, 2022 10:34 PM
dplantz
Jan 4, 2016 04:27 PM
junkyardjeff
May 21, 2014 10:05 PM
obieone1
May 20, 2013 12:28 PM
Brick
Dec 22, 2005 02:40 PM
