2004 freestar starter issues
Old Jul 11, 2014 | 05:33 PM
tyler2004's Avatar
Default 2004 freestar starter issues
Hello
I am having difficulty with my starter on my 2004 freestar 4.2 liter
I am getting 12 volts to the constant terminal but 0 to the smaller starting terminal on the starter I have cleaned the connections and still no luck I have switched relays and have 12 volts at the interior fuse panel any suggestions?
Thanks
Old Jul 11, 2014 | 06:19 PM
Have you solved your vehicle's problem yet?
Old Jul 11, 2014 | 06:22 PM
tyler2004's Avatar
no I have not
Old Jul 11, 2014 | 06:24 PM
What is the anti-theft lite doing when you try to start it?
Is it safe to assume it is an automatic trans?
Have you tried your other coded key?
Old Jul 11, 2014 | 07:03 PM
tyler2004's Avatar
anti theft light is blinking like crazy with both coded keys when trying to start
Old Jul 11, 2014 | 07:11 PM
There is then a problem with the PATS (anti-theft system).
Are there any aftermarket additions on the vehicle , If so try disconnecting it/them and see there is any change. Has something been added and now the vehicle will not start?
Old Jul 11, 2014 | 07:15 PM
tyler2004's Avatar
no aftermarket parts or modifications,
Old Jul 11, 2014 | 07:23 PM
tyler2004's Avatar
if I have a donor vehicle with the two keys can I use the pats ?
Old Jul 11, 2014 | 07:30 PM
The rationality for the PATS on your vehicle is contained in the PCM. This doesn't mean the PCM is at fault , but it could be. If all the conditions are the same and the vehicle started before , it may require someone with a hi end scan tool to troubleshoot the modules. If there is a code in the PCM like P1260 another module could be causing the problem. Sorry I can't offer better suggestions.
Old Jul 11, 2014 | 07:36 PM
The answer to the donor vehicle question is , don't do it !!!!!! It will nullify your present keys and computer .
Anytime any parts are changed you will either need a locksmith with the equipment and knowledge to program the new part(s) to work with your vehicle's computer(PCM) or have the dealership do it. It is called a Parameter Reset.
