2007 focus
Old Apr 28, 2022 | 04:22 PM
Jrdaddyroberts@outlook.com's Avatar
Default 2007 focus
I have a 2007 ford focus. Put new rear drums and shoes. Now it's shaking really bad when on the brakes. Why would new drums and shoes cause shaking? Not the front because u can't feel it in the steering wheel. Help!?
Old Apr 28, 2022 | 04:36 PM
Can you be a little more specific?
Shaking can mean a lot of things.
What happens if you apply the brakes slightly?
There are primary and secondary shoes, are they on correctly?
Was any grease allowed to get in the new linings?
Did you do one wheel at a time so you could compare if installed correctly?
Old Apr 29, 2022 | 03:19 AM
raski's Avatar
I am assuming you did the work, it was verified that the correct shoes and drums were used and new hardware was installed.
Remove the wheels and drums. Examine and compare both to make sure they appear to be assembled correctly. The longer shoe should be towards the rear of the vehicle. Were the contact points on the backing plate lightly lubed with grease? When you put your palms at the 9 and 3 oclock position on the shoes, you should be able to rock the shoes back and forth if everything is free and installed properly. If you rotate the drums, there should be a very slight even drag felt with no high or low spots. Finally, as a temporary test, put the old drums back on if you have them and go for a test drive to see if the problem went away.
DavidJ
May 12, 2018 12:49 PM
Luis R Abbott
Dec 8, 2017 12:46 AM
raidernation
Mar 27, 2012 01:36 PM
mykillove
Apr 29, 2008 09:01 AM
torres
Dec 18, 2006 06:08 PM
