2010 fusion a/c hub
the hub on the a/c compressor separated , didnt really see any other problems so i just replaced the hub. the ac works and has no noises but the new hub is starting to separate also ? any ideas , thanks
Sometimes you need to remove the fender liner to get to it , or , unsecure the compressor so you can get a socket and torque wrench on it.
There is a clutch hub tool to hold the hub while you tighten it to the correct spec, you might want to look into that
