2013 F150 cruise control lower speeds
I have a 2013 F150 and drive long distances at 20mph. I would like the cruise control to come on at 19 to 20 mph instead of 25mph. I called my local Ford dealer and was told it cant be done. Help with this issue would be greatly appreciated.
No, there are no options for a reflash to cure this,, as Ford has designed it to work at about 25 or 30; it's not a problem, it's just not what you want.
Sorry. I just can't imagine anything to do about this. I don't even think a lower gear would help.
Consider this,
The PCM has to take into consideration throttle position, RPM, load and vehicle speed so the cruise control system knows when to respond to maintain the selected speed .
That info is preprogrammed and not easily altered, so if you are determined enough, why don't you install a hand throttle yourself ? It's not that it can't be done, but it most likely is something you would have to do.
renatosc123
Sep 15, 2013 04:08 AM
tcrate
Sep 9, 2011 07:11 PM
