2019 F250 6.2 Electrical issues
Old Apr 16, 2024 | 02:13 PM
Bill82's Avatar
Default 2019 F250 6.2 Electrical issues
Hey, I have a 2019 F250 crew cab 4wd that is having some electrical issues. Full disclosure I bought it with a salvage title due to flood in hopes of fixing up for myself.
The symptoms are
Parking brake randomly pops up on dash as being on while driving. When this happens it can be for a few seconds or currently several minutes before going away. The horn sounds and the door locks lock and unlock
Hazards lights randomly come on after turning the truck off.
The truck can be hard to start if I don't turn the key to on for a few second before cranking.
The truck other then that runs and drives as it should. I have read a lot around the BCM and ECU modules on the truck and it seems to point in every direction. Any ideas or help would be appreciated.
Old Apr 17, 2024 | 11:09 AM
Were you able to determine just high the water level was that the vehicle was subject to?
Do you have any idea if it was fresh water or salt water?
Old Apr 18, 2024 | 07:13 AM
Bill82's Avatar
I could not determine how high the water line was but there was water in the passenger side floor board. I am pretty sure it is fresh water. There is no rust any where on the truck.
Old Apr 18, 2024 | 09:16 AM
You would not believe what salt water can do to copper wiring.
If you can avoid driving thru ANY salted water, by all means do so.
Driving thru fresh water is not good for it either , lol.
Old May 29, 2026 | 01:19 AM
r254's Avatar
** removed message **
Not sure how, but this message posted in the wrong thread. Ignore this, and the reply by hanky below.
Old May 29, 2026 | 04:49 AM
We would think,
PCM controls many assorted vehicle functions ,conveniences and some engine functions too.
Engine control would involve and control engine operating and related functions only
Due to the circuits involved it helps when power requirements are supplied by more than one supplying route.
Helps make diagnosing a little easier too.
A little reminder: just looking at plugs and wires is not thorough enough. The connection has to be unplugged and look inside at the pins and plug material. Corrosion can usually appear as green or white material on or between the contacts that sometimes provides an unintended path for electrical current to go or prevent it from going.
That can result in a short circuit path or prevent the current from going through the intended path .
Old May 29, 2026 | 12:47 PM
You can delete your own post.
1) Click Edit
2) Ignore the "Delete" button, you click "Go Advanced"
3) On top you can see "Delete this message"
4) You can skip "enter a reason"
Fordfrank
Dec 18, 2023 07:36 PM
Virgil
Jan 7, 2021 12:21 AM
Droze1991
Nov 1, 2020 01:57 PM
Figuringoutford!!
Oct 14, 2020 10:00 AM
JimmyDD
Aug 17, 2019 11:44 AM
