500 remote start not cranking
Old Jun 7, 2019 | 05:13 PM
rpsibew110's Avatar
Default 500 remote start not cranking
Hello
My remote start stopped working, it would go through all the steps including beep when I push the blue key button and then beep for crank/startup but would not crank the motor over. Sometimes it would give me two beeps so I checked the brake pedal and hood and found that the hood switch was bad or intermittent so it got replaced. But the remote would still not crank/start the car. After some time and fiddling around with my remote, open close doors and other things that made no difference at all. I sat in the car and noticed the security light in the dash would flash quickly when using my remote. This led me to get my wife remote and try it and it works. So just out of curiosity, I went to the car shut it down (brake pedal) and tried my remote and now it also works all the time. Well, three time in a row which is three times more than 30 minutes ago.
Just an FYI
Edit/update two days later both remotes are not working the search goes on.
Old Jun 9, 2019 | 03:08 PM
rpsibew110's Avatar
I have tried adding a remote to the system and I have wiped all the remotes and readded them to the system. I did test the remotes to make sure they were removed.
The remotes still do not start the car and the anti-theft flashed quickly when it tries to start the car.
I can start the car with the key in the ignition.
I also found that when the engine is to crank and you get the beep(s) I do get one beep and that equates to the ITs ( interior theft sensor) it has always beeped on button press and again when the car started. I do not know if this is normal. So I got into programming mode and made it less sensitive which did not help.
Old Jun 10, 2019 | 07:30 PM
Is this remote start an add on and not an original as built on the vehicle?
Old Jun 10, 2019 | 07:39 PM
rpsibew110's Avatar
It was purchased and installed at the dealership when the car was new. It was not on the car from the factory. "Ford Motor Company PowerCode vehicle security and or convenience system" is what it reads inside on the first page.
Kathy De L'étoile
Nov 17, 2018 05:36 PM
mdvalant
Mar 8, 2015 02:24 PM
savemice69
Jan 11, 2012 10:11 PM
Ventureowner
Oct 19, 2010 10:57 AM
NYCArmyWife
Nov 16, 2008 12:29 PM
