'88 f150 dies when put in reverse
Old May 8, 2013 | 11:01 PM
Andy Spaulding's Avatar
Default '88 f150 dies when put in reverse
Just bought a 1988 f150 and it needs some work. It idles well in neutral and park, runs well in drive, but when I shift it into reverse the engine dies. Any ideas on what I should check?
Old May 12, 2013 | 08:58 PM
greasemark's Avatar
I would start by very carefully shaking (gently) the wiring under the hood and making a very close examination of the loom (especially underneath) where it comes over to the engine from the inner fender. These were very prone to rubbing through the tape and shorting out there.
Good luck, and let us know.
Old May 13, 2013 | 08:14 AM
I replaced the idle control valve and I haven't had an issue with it since, thanks
Old May 13, 2013 | 11:10 AM
IAC, and usually cleaning the throttle body/plate of collected goo will help with idle stability..
kregalmach1
Aug 15, 2012 07:19 PM
weighman
Jan 13, 2011 08:54 PM
crash702
Oct 26, 2008 06:19 PM
work_n_progrezz
May 11, 2008 10:35 PM
drw0392
Feb 20, 2006 09:39 PM
