89 ford f150 need help!!!!!
Old Dec 13, 2006 | 02:09 PM
shadetree216's Avatar
Default 89 ford f150 need help!!!!!
Ive changed engines from a 89 Bronko to a 89 pickup F150, once I was done,the engines was running rough.
I checked all the vac. lines,they were okay,next I pulled spark plug wires to see changes in how it ran, all the wires were firing. but four of the fuel injectors were not working. two on the left side and two on the right side, we disconneted the electrical plugs from injectors to make this determination. Im not sure about sensors and what to check next. I hope you help me, I would appreciate it, thank you for your time.
Old Dec 16, 2006 | 09:32 PM
Malibu Barbie's Avatar
Default RE: 89 ford f150 need help!!!!!
Are the ECU's compatible for both engines? I would run the codes and see if any errors show up. If you can get the truck to AutoZone, they'll check the codes for free.
hubbard85
Jul 3, 2018 09:31 PM
scubadilla4545
Jul 26, 2011 09:36 PM
BigRig Mechanic
Feb 26, 2009 06:12 PM
Ford4life9228
Dec 26, 2007 09:53 PM
f150harley06
Sep 23, 2006 11:29 PM
