95 f150 4x4
Old Nov 9, 2011 | 09:45 AM
dkspattee's Avatar
Default 95 f150 4x4
were having problems with our 95 f150 pickup. it will turn over but not fire and its not all the time. we have checked the fuel filter and its ok, we know its not the pressure valve. it has spark. it will start sometimes if we just keep trying. today it just wouldnt start though. of anyone has any suggestions we are open to any help.
Old Nov 9, 2011 | 10:45 AM
bluewind's Avatar
Clean MAF sensor with MAF sensor cleaner. Clean Air intake temperature sensor. Once you get it running search for vacuum leaks.
Good luck to you.
Old Nov 9, 2011 | 02:15 PM
Just a quickie, if you trip the inertia switch and reset it you will have eliminated one possibility.
Old Nov 9, 2011 | 07:59 PM
greasemark's Avatar
Sounds like a fuel pressure problem, especially if it coughs and 'wants' to start but dies right away. Connect a Fuel pressure gauge when it happens. These old trucks has some problems with the fuel pumps. And also check the fuel pump relay. On something this old, anything could be wrong.
I bet if you did an EEC test, you'd get a 542 (fuel pump secondary circut low), which means the processor saw 0 volts (indicating an open in the fuel pump circutry) when it was expecting to see some voltage. It was a really common problem.
country2
Apr 3, 2008 09:21 AM
skip
Mar 13, 2008 10:46 PM
nicknack24
Feb 5, 2008 10:53 PM
demonpitbull
Jun 23, 2005 11:02 PM
SafariTours
Feb 2, 2005 11:22 PM
