!999 Crown Vic. suspension squeaks
Old Mar 13, 2016 | 03:13 PM
kerley's Avatar
Default !999 Crown Vic. suspension squeaks
I have a high mileage 99' Crown vic Lx 134k. Never damaged in any way and all way's maintained. Lately it has begun to squeak, for example when parked in the garage you can push down on the front or rear corners and the suspension squeaks, we live in the country a 1/2 mile off the paved county road. Our driveway is clay-gravel 1/2 mile to the garage. All tires are near new and all are wearing evenly as it should. It sounds like something needs grease but the car has no grease fittings. I am thinking possibly somewhere a bushing is worn out. Also I noticed that the car does not handle as usual. We recently replaced Tires, Breaks, Shocks and Rear Air Bags. I am thinking that maybe the Air Bag Leveling switch may be defective and causing the car to be out of balance. Have any of you folks ever experienced this, we are at a loss any advice will be appreciated.
Old Mar 13, 2016 | 04:16 PM
What you might try is to have someone rock the car while you listen for where the squeak is originating. Once you pin it down to one area , now you can check from there.
Handling could involve ball joints, stabilizer bushings, even steering linkage. A lot will depend on where you find the squeak coming from.
Old Mar 14, 2016 | 12:01 PM
Alanah_Rae's Avatar
Agreed !!
Old Mar 23, 2016 | 12:35 PM
LakelandFordParts's Avatar
Former Sponsor
Agreed, Fords in those model years are notorious for front suspension squeaks.
Old Mar 24, 2016 | 03:38 AM
Use Common Sense's Avatar
Since rubber is cheaper, most MFGs is rubber bonded to metal sleeves or studs. You probably has a rubber bushing(s) that delaminated from a sleeve or stud. This it squeaks when it rotates/flexes inside the rubber. To locate the critter, start by spraying one bushing with a good helping of silicone and bounce/flex to see if the squeak goes away. If not, go to the next one and do this for everything you can see. Swaybar bushings dry up and loose their grip and will also squeak so don't forget them as well. I just replaced the lower control arms on my 07 Focus for an irritating squeak/groan do to a delaminated bushing from a stud. Happy hunting...
Old Mar 26, 2016 | 12:29 PM
kerley's Avatar
My problem was front Swat Bar Links and Ball Joints. We bought new tires from Pep Boys in May 2014, they also installed two new sway bar links and alignment, The car has not driven well since. I bought the "Rotate and Balance" at an extra cost so I took the car back to them for the Rotation and Balance and ask them to check the suspension. When I picked the car up that evening I was given an estimate of $1400. to replace the Ball Joints. with their brand. I told them I would get back to them.
I took the car to my mechanic and he showed me what was wrong, which was Ball Joints and Sway Bar Links. The Sway Bar Links were worn because Pep Boys did not install the Grease Fittings, the Ball Joints 134K before failure. My mechanic said he would do the repairs for $241. which is what he charged for similar work for another customer, if I supplied the new parts. I ordered the parts from "Rock Auto" on line, total cost $211.06 + $18.00 shipping. The parts were delivered to my front door in two days, total cost $211.06 total cost $452.06 + front end alignment is necessary. I saved $950.
Old Mar 27, 2016 | 11:30 PM
Glad you got it fixed at a reasonable price by somebody you can trust. I just replaced the lower control arms on my 07 Focus. $84.04 to the door for both left and right. Ford wanted $200+tax each while Autozone wanted $105+tax each. Had a 4 wheel alignment also. I hate squeaking and groaning suspensions...
Old Mar 29, 2016 | 10:43 AM
Former Sponsor
I am happy to hear that you vehicle was fixed at a reasonable price.
Old Mar 29, 2016 | 01:16 PM
Alanah_Rae's Avatar
Its really good to hear about your resolving. Thanks for the update @@
kerley
Jul 17, 2015 01:05 PM
Amiee N Lillard
Oct 1, 2014 06:08 PM
jrc_1936
Jul 6, 2011 06:15 AM
ceadamso
Aug 27, 2008 09:31 AM
ky_rescue
May 29, 2007 04:22 PM
