air intake question.
Old Mar 2, 2009 | 03:24 AM
daddy2595's Avatar
Default air intake question.
I have a question, I am thinking about removing my filter box and instaling an after market short ram air intake. It comes with the maf adapter plate.I noted that there is a small sensor on the filter box and that the after market air induction kit does not come with one.
Has anyone had luck with this without throwing engine trouble codes?
Old Mar 2, 2009 | 05:09 AM
Use Common Sense's Avatar
Without the YEAR-MODEL-ENGINE, I would say that the sensor you're refering to would be your Intake Air Temperature sensor. This would need to be relocated into the tube between the filter and the throttle body. Are you going to be sucking cool outside air or hot under hood air with the system you're looking at installing?
Old Mar 2, 2009 | 01:50 PM
daddy2595's Avatar
Default air intak system
Sorry, Its a 95 Ford Crown Victoria P71 4.6 and it will be under the hood but I may try and make a box for it.
Old Mar 2, 2009 | 10:16 PM
Pulling in the HOT under hood air will reduce your horse power output, but will increase your mileage(unless your looking for performance, then the slight loss of HP will cause you to be in the throttle more to try and regain the loss of performance thus using more fuel). Pulling in cooler outside air will increase your horse power, but reduce your mileage (unless your driving easy, then the slight gain in HP will keep you from being on the throttle, thus increasing your mileage).
gman.ricky
Jan 20, 2009 06:41 PM
tcaswell0282
Jan 16, 2009 10:40 PM
GirlFokusZX3
Oct 13, 2006 11:08 PM
elbert
Nov 19, 2005 01:33 AM
dngrrngr93
Aug 9, 2005 05:17 PM
