Brakes low pedal
Old Jan 25, 2012 | 06:56 PM
barkfarm's Avatar
Default Brakes low pedal
Have a 1992 F-350 that I had to put a lot of brake parts in seams like they is air in the lines its a crew cab so lot of line to drain air out of. Had to put vacum booster, master cylinder and 1 rear wheel cylinder on it
Old Jan 25, 2012 | 07:11 PM
barkfarm's Avatar
When batterys on a diesel go bad put 2 new ones in lots of dollars but that is what it takes. Is the pump shutoff letting the the pump have fuel to start or does it use a elec fuel pump? And is the glow plugs working?
Old Jan 26, 2012 | 06:00 PM
way2old's Avatar
Sorry, but you lost me on these threads. As far as bleeding the brake lines, you need to get all the air out of the system. Are you sure you did not depress the master cylinder all the way down the first pump when pumping the brakes up after installation of the master cylinder? If you did, there is a possibility the cups in the MC have rolled allowing the fluid to bypass.
Second post has me confused. Sorry.
surferjoegomango57
Dec 11, 2013 02:32 PM
Michael Leonard Woodcock
Dec 10, 2012 08:36 PM
groho
Aug 25, 2007 08:59 PM
oscar7777
Sep 8, 2006 12:22 AM
dtk11
May 3, 2005 05:37 PM
