Cold start rattle 2018 F150 5.0L
Old Feb 13, 2022 | 07:30 AM
GasCan's Avatar
Default Cold start rattle 2018 F150 5.0L
I have this rattle but only until the motor warms up a little. My question is what happens if nothing is done? Just wondering.
Thanks for any replies.
Old Feb 13, 2022 | 07:59 AM
It gets worse and costs more to replace more parts.
Not knowing exactly what is causing the noise without actually checking it, , but do know that infrequent oil changes with the wrong oil can can produce these symptoms .
If it is what I believe it is, the longer you wait the more expensive it will get to correct.
Old Feb 13, 2022 | 08:35 AM
raski's Avatar
There is a TSB that addresses engine noise on 2018's with the 5.0. I would consult with your dealer for further details. I believe the TSB number is 18-2354.
Sometimes a brief rattle on start up could be something as simple as an oil filter with a poorly performing ADBV which allows oil to escape the filter over time after a shutdown. The rattle would be brief and stop when the filter fills up with oil after the engine is started.
Old Feb 15, 2022 | 04:22 AM
GasCan's Avatar
Thank You for the reply’s
Dr. Pepper
Apr 10, 2022 02:50 AM
GasCan
Dec 8, 2021 02:24 AM
Jsprouse
Apr 4, 2021 11:47 AM
Scott Bruckner
Apr 4, 2019 07:45 PM
brazeagle
Dec 12, 2017 09:27 AM
