DIY: Engine Bay Washing (Video)
Old Apr 7, 2012 | 04:53 PM
ProStreetDriver's Avatar
Default DIY: Engine Bay Washing (Video)
DIY: Engine Bay Washing - YouTube
How to wash dirt, grease, or grim away from your engine bay. Make sure your engine is cool when you do this procedure. Spray the solution onto the engine and around the engine bay, let it soak for approximately 5 minutes, then continue to rinse off with hose or pressure washer. Let engine dry for a few hours to prevent the vehicle from running rough.
The soap I used in this video is called Spray Nine, but I'm sure there is other cleaners available which will do the same job.
Areas to take caution around when washing:
-alternator
-coils/distributor
-spark plugs
-spark plug wires
-fuse panel
-oil filling places (engine oil, transmission oil, power steering)
-brake fluid reservoir
-intake
-air filter
To protect any areas you are worried about water entering, you can cover it up with a plastic bag.
ProStreetDriver
Aug 23, 2013 11:15 PM
ProStreetDriver
Apr 14, 2012 12:40 PM
ProStreetDriver
Apr 14, 2012 12:38 PM
ProStreetDriver
Dec 19, 2011 10:50 PM
daveranger
May 24, 2007 12:56 PM
