E250 engine harness. 4.2
Old Aug 13, 2013 | 10:44 PM
Petrocnj's Avatar
Default E250 engine harness. 4.2
I purchased a 1999 e250 with a new long block that needed to be installed. After installation, I was told that the engine had the wrong engine harness. How difficult is it to replace the engine harness and should I spring for a new one or is a used OK?
Old Sep 2, 2013 | 08:16 AM
diyautoelectric's Avatar
What's wrong with the harness ? where is the one that used to be in the truck ? a used one should work fine.
Get a subscription to the wiring diagrams and you may be able to just wire up what ever is different or missing
Do it Yourself Online Automotive Repair Information. <a href="http://affiliates.eautorepair.net/z/24/CD10493/">Click Here</a>
Old Sep 3, 2013 | 05:40 AM
Use Common Sense's Avatar
Where did they come up with the engine had the wrong harness?
Last I knew. a long block is a complete engine, except a long block normally requires the external parts like harmonic balancer, valve covers, exhaust and intake manifolds, flywheel, timing cover and oil pan.
Therefore..with that said, you would be reusing all other parts from the old engine which would include the original engine/wiring harness. What did they do??? Chop up the old harnes to remove the original engine?
warrenp099
Sep 8, 2013 02:09 PM
tennesseesaturn
Aug 31, 2011 06:15 PM
Dingo
Sep 1, 2009 08:17 PM
lilblueford88
Dec 7, 2007 01:48 PM
JWA
Jun 7, 2007 07:37 PM
