Electrical Fades while Running
Old Jan 6, 2008 | 02:43 PM
yamagobo's Avatar
Default Electrical Fades while Running
Hello everone!
Im in need of some opinions. I have 98 Expedition 4.6 4x4 with 145k miles on it. While it was running the battery light came on and about 10 mins. later my headlights and every electrical components started to fade then shut off while the engine was running fine. Eventually everything shut off.
2 hour later started up perfecly, but then the all the electrcal faded again like before.
Not sure if this is related, but 2 weeks ago I was installing a cd player and the constant and ground touched and heard a small pop like a fuse went out- strange thing is, checked all the fuses and they were good!?! unless there is another fuse box I dont know about other then the one next to the driver side left knee and the one underneath the driverside hood.
I will get some codes in a bit
Any advise as to what the problem could be would be apreciated, im really low on cash and need to fix myself to get to work.
thanks
Old Jan 6, 2008 | 09:46 PM
yamagobo's Avatar
Default RE: Electrical Fades while Running
So the battery is good, im guessing its got to be the alternator.
Old Jan 19, 2008 | 04:07 PM
b rabbit's Avatar
do you have a mulitmeter if you do , start the car and check batt voltage(@ the batt post) it should be between 14-16 , did you check you fuseable link that may of been the pop you heard but two weeks on just the batt seems like a long time buy hey any things possiable.the fused link should be right next to your batt in a red case .
willijimon
Oct 21, 2018 08:07 PM
Fireside
Jun 22, 2014 05:07 PM
96F350Panel
Nov 27, 2007 02:59 PM
Kim
Mar 9, 2006 07:12 PM
jk16201
Sep 13, 2005 04:04 AM
