Expedition Window Problem
Old Jun 15, 2009 | 10:16 AM
Belvedere's Avatar
Default Expedition Window Problem
I have a 2005 Expedition. I'm having a problem with the pass. side power window. It started out that it would roll down, but not up without hitting the button about 50 times (like a short). Now it won't go either way. It's not the motor, already tried one. I've got 12 volts at the plug to the motor. Any suggestions?
Old Jun 16, 2009 | 09:24 AM
XMKTech's Avatar
You can try using a jumper wire at the harness of the switch and see if it goes up or down. Does it work when you only use the master switch. Try jumping at the passenger door switch harness and the there reconnect and repete at the master switch. I wish i had a wire diagram i could help you out with although i do not have access to that info outside of work.
bcmartha
Apr 4, 2014 02:08 PM
fishfun83
Apr 23, 2012 01:34 PM
Geekhead
Aug 9, 2011 10:34 PM
300zxmuro
Jan 31, 2006 11:47 PM
Auburn
Jul 19, 2005 11:19 PM
