f150 quad coil pack failures
Old Jan 19, 2006 | 12:11 PM
jquay's Avatar
Default f150 quad coil pack failures
My 97 f150 4.6L V8 has repeated quad ignition coil pack breakdowns. They are lasting an average of only 4-6 months. I have replaced these several times. Failures have appeared on both driver and passenger sides and the average lifetime is decreasing. I strongly suspect that another igntion system problem is causing the coil paks to break down. I have replaced spark plugs and wires. How likely is it that the voltage regultor or alternator is defective and overvoltage stress is ruining the coils?
Old Jan 19, 2006 | 08:36 PM
way2old's Avatar
Default RE: f150 quad coil pack failures
Do the coil packs have the little condenser like attachment onthem? If it does, I would look closely at them.
Old Jan 24, 2006 | 09:58 PM
Old FE Buzzard's Avatar
I have only seen this type of problem resulting from bad plug wires. Are you sure the replacement wires are good? Ever buy a brand new defective part? Check the resistance of each wire with an ohmmeter. Any measurement greater than 6,000 ohms is definatly bad.
Also, the obvious. Be sure the wires are completely seated in both the coilpack and the spark plugs
makuloco2000
Aug 25, 2014 01:07 PM
SixxiA
Jan 29, 2014 08:42 AM
Cowboy_80
Apr 29, 2008 12:34 AM
yellowbird
Mar 7, 2008 11:09 AM
rlevy64614
Jun 8, 2007 08:55 PM
