FEM ID and location in 2001 windstar?
Can anybody tell me what the FEM (front electronics module) looks like and were it is located in a 2001 Windstar? While on the road this past winter (when it was very cold) my wife had the drivers side window stick in the down position. She had a Ford dealer check it out and they said that it was the FEM. To get her back on the road they jumped the window motor and rolled it up and then disconnected the FEM so the window couldn't be opened again. I would like to fix it but I don't know what I am looking for. I tried searching here for info but couldn't find anything. Thanks.
Here ya go.
Front Electronic Module (FEM)
Removal and Installation
CAUTION: Prior to removal of the FEM, it is necessary to upload module configuration information to a diagnostic tool. This information needs to be downloaded into the new module once installed..
Disconnect the battery ground cable..
Remove the instrument panel lower steering column opening cover.
Remove the bolts. Thumbnail 1
Remove the instrument panel opening cover reinforcement.
Remove the bolts. Thumbnail 2
Remove the front electronic module (FEM).
Disconnect the five electrical connectors.
Remove the three bolts. Thumbnail 3
CAUTION: Once the new module is installed, it is necessary to download the module configuration information from the diagnostic tool into the new module.
To install, reverse the removal procedure.
Mmmmm, looks like a trip to the dealer with a used FEM or maybe hook it back up and jury rig the window switch. Thanks very much.
ps: The dealer actually suggested a used FEM because new would be so expensive.
