ford e350 van problem
Old Mar 4, 2012 | 12:11 PM
caddyguy's Avatar
Default ford e350 van problem
Hello all. I have a ford e350 superduty cutaway service van. It is 2004 with 175000 miles on it. Recently while on the highway, it started making a woo woo noise from the front end. It still does, but after 40 mph and it gets louder if I turn right, while moving. If I turn left while moving, it goes away. I brought it in to a front end shop and had the ball joints and wheel bearings replaced. Nothing else was evident as a fault. Drove it and the same thing. Brought it back in and was told that the front rotors and calipers needed replacement. That would be the culprit. I p/u the parts and replaced them my self with new pads. Test drove the truck, same thing. I don't know what it could be? Can someone help with this please? Thanks in advance. Geo.
Old Mar 4, 2012 | 01:24 PM
Will it make the noise at the same RPM but the vehicle not moving?
Old Mar 4, 2012 | 02:34 PM
greasemark's Avatar
Or is this a possible rear end noise that is being telegraphed throughout the chassis?
Old Mar 5, 2012 | 06:10 AM
caddyguy's Avatar
It only makes the noise when driving, sounds like a woo woo rubbing sound. It comes from the front left side. I will see what it is like today. Once it warms up I will rotate the tires and see if it makes a difference, but I doubt it.
Old Mar 5, 2012 | 01:43 PM
You could try this; go under the van and look at the U-Joints. Look for any rust at any of the crosses and their bearings. I believe there are 3 U-Joints , the rearmost one usually goes first. You're going to get a lot of things to look at .
Old Mar 5, 2012 | 08:01 PM
caddyguy's Avatar
I found the culprit. After driving to the job site, 50 miles on the hwy, with a clunking sound and a new grinding sound. I found the rear drivers side tire sitting on an angle. After removing the hub cap I saw the lug nuts at the end of the threads, all 8! Rim is trash since it was free riding along the hub. Now I need 8 new studs and 8 new lug nuts, new rim. Can't believe that a shop could not find this? Thank God the wheel did not come off while driving!Geo. U joints are fine, I checked those already. Geo.
Old Mar 6, 2012 | 03:49 AM
Glad you found it too, before it found you.
Old Sep 12, 2013 | 03:57 PM
ofski's Avatar
Hi everyone, am new in this forum and also having the same sound from the front left tire i.e. the driver's side. Am 100% sure this is the same issue with my too. I will check that tomorrow morning and update you all. Thanks am begining to enjoy this forum. Thanks a lot Caddy.
Sad Ford Fan
May 8, 2012 04:27 PM
terrifictoy
Mar 11, 2011 10:15 AM
nickgrigg
Feb 28, 2007 05:20 PM
baahaa
Feb 8, 2007 01:53 AM
viperolu
Mar 19, 2006 12:52 PM
